Considering that Prodigy has promotional material showing their 3.8 12 psi turbo jeep lifting the front wheels in the air at a drag strip (and they are the only forced induction option to do this with a Jeep), and that Prodigy claims to have the most powerful forced induction option for the Jeep, I think it's quite reasonable to conclude that the following was in reference to Prodigy, and could imply that Prodigy is sacrificing reliability for power:
Prodigy's point above was that both Prodigy and RIPP are running similar boost levels, so the Prodigy turbo isn't necessarily stressing the engine more than RIPP to get more power. With the supercharger, there is more parasitic power loss to directly driving the supercharger itself. A turbo is inherently more efficient, so a larger portion of the internal forces/stresses produced in the engine are actually transmitted to the drivetrain. A supercharger would need to produce more boost and internal forces/stresses in the engine to match the power output of a turbo. If there was another competitor with a centrifugal supercharger using more boost than RIPP to produce more power, then it would be fair for RIPP to bring up the question of reduced long-term reliability in that competitor's product.
Let's just assume that RIPP did not intend to imply anything about the reliability of the Prodigy turbo, and instead assume that RIPP was simply saying that they are comfortable with their current balance of power and reliability within the context of their own centrifugal supercharger platform, and that they choose not to sacrifice reliability to increase power output and try to compete in peak dyno numbers with a competitor's offering that has an inherent advantage in power production efficiency.
Like Prodigy said, all the forced induction options have different pros/cons. Designed properly, they can all have similar overall reliability, but differences in peak power, throttle response, shape of the torque curve, etc. Peak power/torque is not everything, so there's nothing wrong with not being the most powerful option. None of the forced induction options are inherently overall better/worse. We all have different priorities and desires.
