Next up was preparing to remove intake manifold. First off I had to unplug and remove the vacuum lines behind the throttle body, unplug and remove the map sensor, and unplug the throttle body. Then I unplugged the large data plug just to the passenger side of the manifold. Then I pulled the harness from the manifold by pulling the plastic push clips. Hint** A pair of 45 degree long nose plies came in handy each and every time I had to pull the plastic clips or screws during this install. None were damaged and all were able to be reused.**
