The space where your stock air box was will now be utilized for the new coolant overflow tank. Use the template they supply to mark and drill 3 holes through the plastic. Place tank mount in, aligned with holes, drop hardware in mounting holes, use supplied clamp, nuts, and washers and tighten. Slide tank onto bracket until it bottoms out. Route coolant overflow hose from radiator.
