Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Junior Member
    Mar 2014
    Elmwood park nj
    need help with check engine light
    My 1998 cherokee threw a 7005 code which has to do somthing with the trans and the nss neutral safty switch...I replaced it and now have reverse lights but clesred the code and it just keeps comming back...anyone know how to solve this problem my inspection was up last month and need this fixed so I can get her back on the road...
    OMG thats the first question you guys get?
    If you replaced the neutral safety switch and you're still popping codes after reset, then it wasn't the switch that was the problem.
    Here is someone with the same issue on the same vehicle: http://www.cherokeeforum.com/f2/neut...-switch-22552/
    Unfortunately the original poster didn't continue the thread to resolution.
    Junior Member
    Mar 2014
    Elmwood park nj
    thank you snarf77....i bin at this for a couple of weeks now ...the truck runs and shifts mint just every time i clear the light it comes back...thanks for the help...back to the drawing board....
    Longfellab did you replace the neutral safety switch yourself?
    If so I have heard loosening the retaining bolt, and rotating the NSS clockwise a little bit could work
    Quote Originally Posted by Frank The Tank View Post
    WHOA! Frank for the win!
    Now i want to see if that fixed it.
  8. #8
    Junior Member
    Mar 2014
    Elmwood park nj
    Yes I did replace it and I forgot to check that ...thanks bud ...I will let you know if that fixed it....
  9. #9
    Junior Member
    Mar 2014
    Elmwood park nj
  10. #10
    havent won yet haha, just offering up what I have heard
