Results 1 to 10 of 12
    I started by removing all the Krawler joints and the flex joint bushings. I used a 5/8" socket to push out the center sleeve.:
    Attachment 1032
    Attachment 1033
    Once the sleeve is out, there are two bushings that need to come out from each side:
    Attachment 1034
    Attachment 1035
    I also used a parts cleaner with a very mild cleaning agent to clean all the grease and crud that were on the Krawler joints themselves.:
    Attachment 1037
