That looks like a nice system.
2013 Wrangler JKU - Rock Lobster Red, Smittybilt SRC rear bumper and side steps; RR drop in reusable air filter; Quadratec floor liners; 285/75-16 Falken Rockey Mountain ATSII, Rebel Offroad grab handles and fire extinguisher holder.
OK, here are the control arms that were sent from Ross and a couple of close ups of some of the joints along with a Monster Pro joint that is brand new:
This shows a joint that has the innards hanging out. I contacted RK and they said that the joint is still good as long as the joint, as a unit, doesn't just flop around.
A new Monster Pro along with a standard Krawler Joint:
A little closer view of one of the arms:
I started by removing all the Krawler joints and the flex joint bushings. I used a 5/8" socket to push out the center sleeve.:
Attachment 1032
Attachment 1033
Once the sleeve is out, there are two bushings that need to come out from each side:
Attachment 1034
Attachment 1035
I also used a parts cleaner with a very mild cleaning agent to clean all the grease and crud that were on the Krawler joints themselves.:
Attachment 1037
At this point I had a decision to make. I thought about taking the control arms to get new powder coating, bedline the arms, or just paint them. I decided on just painting them with some self-etching primer, satin black, and then a gloss clear coat. That way, when they get scratched I can just touch them up. The bed lined option would have been nice but I received a new full set of control arm decals from Rock Krawler that wouldn't stick very well to the rough surface of bed liner.
I broke out the ol' sander and took the arms completely back to bare metal:
I then cleaned and then sprayed the self-etching primer:
I then sprayed a nice satin black, followed by a good clear coat. The final pic so far is of a finished front lower (top) against another lower that has yet to be redone. Also attached is the Monster Pro joint:
I sprayed each coat of paint several layers thick to give a nice heavy-duty coating of paint. As of right now, I have 4 arms completely done, 3 that have been primed, and one that hasn't been sanded.
I called a local off-road shop to see what they charge to install these as they may be more than what I want to get into. They quoted me $425 for the install, not including alignment. I would have to go elsewhere for that.
I then read through RK's instruction manual to see what all was involved in the installation and I may just do it myself. I can think of $425 on other products I would like to have.
Stay tuned...
