Quote Originally Posted by 40inchDozer View Post
So my driverside front power window started to act up about 2 months ago. Worked going up but was acting up when I wanted the window down. So I delt wirh this for 2 months now but now it doesnt want to go down. And if for some reasonbi do get it downnthe up works perfect. Im thinking the switch might be bad .I have looked for a pin fit in the connector and the motor works so the switch seems like a good spot to start. What does everyone think???
FIRST POST!
long time lurker. I like the JL site for the real discussion here. not much of that "which lift is best" crap. Those rookies can flood forums, no time for all that.
I have this same window problem, i thought it was the motor, what makes you think its the switch?
Are you going to open the door up? If you do please make your plan clear. I can handle a tool set but am by no means a mechanic.
