Sounds good! And for the record... You don't have to remove the dash to take out the switch. As I said, just grab the center of the switch and pull, it will pop right out of the dash. I still think you should go the "ask a cute JK chick" route while you can, even if you now suspect the problem to be with the motor in the door. Those opportunities don't present themselves all the time you know!
