Results 1 to 4 of 4
    Mar 2014
    Southern Illinoi
    DIY mirror mounts
    Well couple weeks ago decided I needed some mirrors and a way to mount them. Didn't want to spend $60.00 on a set that wouldn't be used all that much as my wife is against the doors coming off. So after doing some research I decided to get some cheap motorcycle mirrors off of ebay and make some mounts from a gate hinge.Click image for larger version.
ID:	1121 http://www.lowes.com/pd_64172-1277-9...r|1&facetInfo=
    From there I cut the ends off of the hinge leaving one bolt hole and a part of where the pin goes through. I didn't cut the straightest, but I was using a cheap vise and hacksaw. Cleaned them up and shot them with spray can bed liner. Picked up some stainless steel hardware and there you have it, I also had some rubber gasket material from another project and placed it behind the mirror brackets. Total investment mirrors hing and bed liner which I purchased for other projects less than $25.00.
    Nicely done. I like the DIY section!
    Genius. Well done
    Mar 2014
    Southern Illinoi
    Thank you, is there a DIY section of the forum? Should one be started?
