Results 1 to 10 of 43
    I had to modify my artec rear truss to work with the metalcloak gamechanger lifts Bolt on high clearance track bar bracket. Had to notch the artec and weld the bracket to the truss. This would be more helpful with pics...but I don't have access at the moment.
    Artec also makes a rear track bar bracket, adjustable.
    Do these trusses add a lot of weight?
    They don't. The sides of each truss is .130 and the top is 1/4 steel. Total weight of the front is under 11 lbs.
    The rear is smaller, so will be less.
    I didn't notice any difference in drivability with them installed. You don't even know they are there.
    I concur, these aren't terribly heavy and the benefits are tremendous. Both of mine came in one box and I was able to pick it up easily (was prepared for something heavy). I'm pretty sure that the welds give it the necessary strength.
    Those holes do too. The holes throughout the flat pieces are not flat, They are pressed. and make it rigid.
    Just a shot of my front Artec kit and Ballistic Fabrication Diff Cover, metalcloak gamechanger arms.
Name:	2014-03-08 15.48.25.jpg
