The install was super easy as before. Engo supplies a very nice harness with the lights that has everything you would need in ample length to install as if it were your only accessory. My install was made much easier with the sPod. Plug and play. Engo uses top quality waterproof connectors as well. I don't think the connectors would ever be a problem as they have the automotive style sealed plugs similar to jeep oem.
Install was a breeze. These tilt up and down a bit less than the 4" flood but also have a lower profile, cleaner finish.
Name:	2014-09-15 18.45.58.jpg
Name:	2014-09-15 18.46.15.jpg
Name:	2014-09-15 18.52.23.jpg
Name:	2014-09-15 18.53.03.jpg
Clearance was tight with the passenger wiper, but it always is with the mounts I use. It still clears by a couple mm and its never been a problem. If it became a problem, I'd just make the hole a bit wider and move it a couple mm further out.
Name:	2014-09-15 18.52.45.jpg
Its strange having smaller lights on the jeep after being used to seeing the large 4" floods on there for so long. I'll have to get her out on a clear night and try to get some pattern pictures to compare with some other lighting patterns we've seen. I also saw Engo is now offering these in a flush mount for mounting in-body or in-bumper. Very cool!
