They make a complete kit for the JK that is headlight, fog light, and turn signals, but it will not fit the JW speaker headlight. JW fog and stock fog are the same. The standard stock fog film will fit the jw speaker fog.
The JW speaker headlight requires a different pattern that is under development right now. (ill credit myself for that. lots of begging by me)
If you want a set that is correct for the JW speaker, PM me. I will get you in contact with my friend over there. The standard JK headlight film will not fit the jw speaker headlight. We are using film from a harley motorcycle that we figured out was the same size, and it turned out to be dead on.
Once they have a name and item number for fitting the JW speaker headlight i will post it.
