Results 1 to 8 of 8
    x3 on supercool. did you ruin the center cap to put the brake light on it?
    Well..I don't like to think I "ruined" it. But if you mean can it be used as a normal center cap now, then the answer is no. I had to drill out the center of the center cap to securely mount a brake light in the metal. Its in there affixed from the rear. If the light goes it can be replaced, but the cap is always going to have a big hole in it!
