Quote Originally Posted by Matsango View Post
I called billet technologies to order the catch can but I didn't know what diameter hoses, lengths and fittings are needed. Any insight on how and where it gets plumbed? Or maybe some pics of connection locations
If you're installing on a 3.6L Pentastar then the PCV port on the rear of the right side valve cover is 3/4". That's where the crankcase gasses exit the motor. The stock connector reduces the PCV line from 3/4" to 5/8" which is the size of the plastic lines running under the hood. Billet Technologies can fit their catch can with whatever size barbed connectors you need. If you mount the can in a remote location then I recommend hard (plastic or stainless steel) lines rather than rubber tubing. Long hoses that get hot under the hood can (will) collapse under suction which will throw the computer off. Oh, and the make-up air return line going into the rear of the left side valve cover is 5/8" (I'm pretty sure).
