Has RIPP also figured out the auto shifting? The instructions I got from them a while back state you need to lift to shift during heavy acceleration.
That was from months ago, so it's possible this has changed. The last line, while I understand is a CYA statement, also worries me a bit.• Automatic transmission: Auto transmissions may not up shift at full throttle when driving in “D” (drive) mode, THIS IS a Direct product of OEM programming and not the provided tuning. In order to shift at full throttle, end users may either “lift to shift” by raising the accelerator slightly (partially). RIPP makes no claims as to the reliability of the transmission with the supercharger installed.
