Results 1 to 10 of 171
    Initial thoughts: at first I wasn't impressed. The acceleration wasn't there and it was noisy. On day two my opinion changed. I actually gave it more than 20‰ throttle and I was impressed. I was used to my V8 that makes a lot of noisy when it goes. This doesn't. It just spins up and goes. My son says it sounds like a race car. You can hear the blower when you give it gas. It accelerates like a bat out of hell. I haven't given it full throttle yet. There has been no need to. I am at Highway speeds before I even hit the end of the on ramp.
    I was worried that it would be loud at cruise speeds. It's is there but not bothersome at all. With the stereo going you can't even hear it.
    Pros:
    Wicked acceleration
    Sounds cool
    Power band is where I drive.
    Cons:
    Fuel economy - about 12-14 mpg. It was 16+.
    Burns premium
    I think the fuel economy will get better. The current program tends to have the transmission shift at 5k. I have noticed that I can tap the shift lever and make it shift at lower rpm which should help. I will track that more when I get home.
    It is 5 o'clock. So we all know of what that means.
    Quote Originally Posted by Icheer4beer View Post
    There's definitely a need to use full throttle... a need for SPEED!
    I used full throttle with my turbo about 10 minutes into my first drive
    BTW, this is from Sprintex's facebook page: https://www.facebook.com/sprintexusa...301300/?type=1
    Boom! This is a stock Jeep on stock tires with a stock Sprintex Supercharger intercooled 3.6L system. 6spd, nearly full tank of gas.
    This is an incredible 0-60. What's the gear ratio? Id like to do some math on it.
    Must be a stripped down 2 door
