Just a thought Ross. But the catch can should have a drain back path that is gravity fed back to the crankcase. Otherwise it just continues to fill every time you punch it. Another words the can should be mounted higher than the hose feeding it. Then the oil will be able to drain back when the boost is not pushing air to the intake side. Does that make sense. Or did I just confuse you.
