I run LoD's Signature Rock Sliders. The reasons are these:
1: Have integrated flat plate areas on top that give you sure footing to stand on so they can be used as an actual step.
2: Tie directly into the frame for a good solid anchor point.
3: The angled sides have slide plates that can be removed to save a tad bit of weight, if needed, but also gives visual appeal when attached.
4: Made from steel and built right in Indiana, USA.
Granted they probably aren't the lightest set on the block and I have yet to drop them on anything other than myself while laying under them during the install, I have every bit of confidence they will do their job when the time comes.
- You may not post replies
- You may not edit your posts
