The arrow on the brass check valve indicates the direction that the valve will allow air to flow. It should point toward the intake manifold, like the red arrow in my picture. You can even double-check that the arrow on the check valve is correct by trying to suck air through in the indicated direction with your mouth. It might take a bit more force than you expect, so if it seems to not work in either direction, just suck harder
