This video will show the components we are going to use. Its the 1350 set up. heavier duty.
Jesse's girl has all yukon components, alloy rear axle, chromoly fronts. If you toughen up the axles, you should go with the tougher drive shaft. Let me tell you why-
The question is, under stress, eventually something will break. Whats that thing going to be? It could be your axle, or your drive shaft....or something more vital in your transfercase or transmission. So if you beef up the axle, you want to beef up the drive shaft appropriately.
