Sooo tempting
Sooo tempting
You guys seem bent on weight... And bent on 37s.
is weight a big deal with smaller tires? Or should i make my tire pick based on weight rather than tread?
The bigger you go on tires, the more serious weight becomes.
Smaller tires, it means less...but whatever you do to your new jeep, realize that everything ADDS weight. Very few mods make your truck lighter.
Every ounce drains your power. So yes, weight is the first thing i look at for tires. tread is second.
You will find, the manufacturers that make the lighter mud tires also make the best treads and spend the most research on development. BFG and Goodyear.
I think the first thing you should consider is your location and how you are going to use you jeep. Then pick the style that suits your driving conditions. Then compare all the brands that make that style tire and compare their weights. Finally pick which one fits within your budget.
