It is actual stainless steel. I have brazed stainless before, I hope my dad still has some sticks to use. I don't want to buy a box of sticks for 1 pin hole. I will try to video it, but my plan was to do it while installed. A lot will depend on how easy it is to get the current muffler off if I change it out. It took me several times to get the pipe in the correct position to avoid leaks. In my opinion the mid pipe needs redesigned, to get the all pieces to install you actually have to put everything in a bind to get it to line up. The last bend needs to be further back or possibly removed.
