Quote Originally Posted by ljvsnyder View Post
This is the response I received from them today.
"This doesn't appear to be a leak. The mufflers are welded on a mechanical spinning jig. What you can't see inside the muffler is the weld on the inside. So while it may appear to be a hole on the outside at the weld there is a weld on the inside 360°"
Photos of the leak.
You should put something on it like soapy water start up the engine-- if it bubbles it leaks! Take a video of it bubbling and send it off to the company. There response will be humorous to say the least.
