Results 1 to 10 of 26
    Those hoods look like they'd be useful during the summer to get rid of some heat in the JK's engine bay. I'm switching to the metalcloak aluminium inner fender liners and metalcloak says they are good for up to a 30 degree heat reduction. I bet if you combined them with a hood like this (I like the color matched!) the air allowed in with the more open fender wells would vent up through the hood when idling and then in the front of the hood when moving.
    That is cool. For the most part the hood is closed except right over the intake. I would like to see those finder liners, Please post pics when you can.
    Here is how they work. With the Metalcloak Overline fenders (overland as well), you remove the plastic liner and replace with some precision bent aluminum pieces shown here in red:
Name:	fender liners.jpg
    I've powder coated mine matte textured black and they should be installed in about two weeks. I can get some better pics then. They seem like they'll keep the mud/muck out where needed while concurrently adding a ton of airflow.
    from the pic, it looks like theres a space where mud can splash thru. Do they overlap?
    No, they don't overlap. They simply cover the open areas that lead to the engine bay and components. The places they leave "open" are where the mud/gunk/salt will hit other surfaces like the tub, frame, etc. Not as much protection as a giant plastic bowl of a stock fender liner but better for air movement, access, etc.
    I think those inner fenders from Metal Cloak would be good for heat reduction, but im not sure about how much heat is going out of the channels of the RKsport hood.
    The hood takes the air and forces it down to the intake, which is fantastic for cold air, but for helping hot air escape im not so sure. The perhaps at high speeds, the hood would force the hot air of the engine bay out thru the inner fenders, and at low speeds, the hot air may escape through the intake to the rear vents.
    My meaning is, you can see the large vents in the rear of the hood. You'd think they were great for heat reduction, but they are not directly open to the engine bay. They are connected to channels that lead to the nose, and to the intake.
    So the difference between this RKsport hood and Deola's Heat Expulsion hood is that one sucks air in on purpose, and the other spits it out on purpose?
