And don't forget that winches are usually rated on the first wrap of cable on the drum. The more wraps on the drum when you start winching the lower the rated pulling force. Good post.
That is true. I've never liked the way most winch charts say One wrap- is that one wrap of cable off or on? Intuitively, I always think that is with one wrap off the drum and have to correct myself that it means that maximum pulling is done with one wrap on the drum.
This is another reason to always have a snatch block or two with you. You might need to use them to change your pulling force so you can secure yourself far enough away from the vehicle to use a single line pull of maximum strength. However, with most electric winches for these vehicles you never have much more than 120ft of wire or synthetic rope on the drum.
