Results 1 to 10 of 47
    I didn't say race applications were the best for diesels traditionally speaking. I simply said power and my statement is correct! You can turn a Cummins BT 4 (inline 4 cylinder and 3.9L) engine from 120hp to 800hp or more without really any effort. And that would fit into your Jeep very easily! And while traditionally speaking the Diesel Cycle is not the first choice of race cars mainly due to the fact that they have lower redline limits. Today's modern high-speed diesels can rev-up to almost 7000rpm. So, yeah if you could afford an Audi TDI V10 5.5L race engine you would get about 590hp and 774ft-lbs of torque. Or stick a Peugeot HDI 908 5.5L V-12 that made about +700hp. Myself, I care more about just simple power and well a cummins BT4 sucking on WM-50 with 80PSI of Boost and fuel pressure from the pump at about 100PSI is a 900+HP combination. Oh and this actually probably at the wheels... And the best part is you really don't have to all that much to the engine to these types of power out puts. Where as to get 900HP on pump gas for a 6.4Hemi conversion is a serious undertaking. Where as the BT4 modifications are very very simple to do.
    So, perhaps, you might want to retract your statements and bring them into line with reality??? Or not... I'm just discussing power options-- i could care less about acceptance. You people want to talk about power and my suggestion is go Diesel. The Hemi Conversions and other V8 power options are okay. But if you want to play with pump fuels and not spend up to 100K on making the engine work at above 1000hp ratings-- Diesel is your only option really. Most of the engines you find in the $15,000 USD range that street engines top out at 700-800hp over a 1000-1500hp and you're looking at 30-45K and 1500-2500hp you're talking in the 60-100k price. So you take that same 15K and you spend it on a diesel and produce 1100Hp-1500hp easily. Spend about 100K and you can turn a big size diesel into a 3000hp to 4000hp monster! But, a nice little BT4 running a nice tune could easily get you +900hp at the wheels for about $8.500 and the rest is spent putting into the frame.
    But that is why you don't get it. This is a perfect option for a Jeep if you ask me. It gives you everything you want more power, and more torque. And if you do it right you won't even have to worry about top end speed. So tell why isnt' a diesel option perfect for a Jeep's primary application? Other than you just don't know what you are talking about?
    I didn't say derpy derpity duuurp the derpity for derpity derpy duuurp.
    Actually, that's essentially what it looks like you said to me. Then again, everything you say looks like that to me
    Rock On Cork!!! Rock On!!!!
    Huh... a video has now mysteriously appeared in the original post in this thread that suddenly the whole point of this thread more clear.
    https://www.youtube.com/watch?v=olHEykVL9t4
    All I See Now...
    Although... that video hardly reveals the "secret to more power". The basic kit is only about 140 hp, and can be "turned all the way up" to push 250-300 hp. That's a whole lot of money and major conversion work for to get less power than the stock Pentastar. Then a whole lot more money to upgrade it to be more powerful.
    (yes, I know there's other advantages to the huge low-end torque, but the title of this thread was "the secret to more power...", and in that regard, the initial post fails to deliver)
