You might want to use Automotive type multistrand wiring. I would stay away from single strand wire. However, I don't see why you need a relay to make this light work-- you want a constant operation on the light right? So you flip the switch and the light stays right? So, I would just wire into circuit with the either the rear lights--so when you back up it goes on. if you have spot on your S-Pod just make an independent switch for it with a fuse between Spod and the lights.
