You're going to need more than just springs-- you will also need new shocks and probably should upgrade the bump stops... As for spring rate weil you will have to get an accurate measurement of the trucks front end weight and then work out what you want to do with the Jeep. Are you going off road with it ever or just moderate stuff or is this a pavement only basically vehicle? The setups will differ radically and so will the costs.
http://www.ridefox.com/filter.php?ma...uck&ref=topnav
