Results 1 to 4 of 4
    Mopar hood lock with Ripp supercharger
    Found the link below and tried it and it worked out pretty good. You basically have to take it apart and cut 1/2" strip off the housing and the latch and then weld them back together. Then two new holes drilled right above the intercooler mounting holes.
    http://www.jk-forum.com/forums/jk-ta...lock-216763/#b
    Very cool. Is it keyed to match the doors?
    i like it. i hate the idea of someone messing with my engine.
    Yes the mopar hood lock gets keyed to your key the first time you turn it. I had it from before so I modified it and it worked out.
