Results 1 to 10 of 73
    The InTune (handheld tuner that comes with the Prodigy kit) does not do 0-60 or any other performance measurements like the Trinity does.
    If you have an Android phone/tablet, you can get a bluetooth OBDII adapter and purchase the "Torque" app, which uses the OBDII adapter for monitoring, data logging, and also does 0-60 and 1/4 mile measurements.
    I have a BT adapter and paid torque app. I might have to do a 0-60 video. Depends on how much i value my clutch. I'm guessing its around 6 seconds or perhaps just under. But..my guess means nothing. its truly all about the launch and a 1st to second shift. I think the real beauty of the turbo is the passing performance..call it 20-60 or 30-90. That's where your drive-ability comes into play.
    Gotta get there in second gear or you have no shot at 6 seconds. I was only ever under 6 seconds COMPLETELY pushing 2nd gear into the red. If you have to shift again, you will not make it.
    I think you might be screwed regardless with 4.88s. You might not do 60 in second gear.... Pickles? the math?
    Depends on tire size. I hit 64 mph at the end of 2nd gear with my 3.21 gears and 28.5" (actual size) stock tires.
    So a quick calculation shows that you would need at least 40.6" (actual size) tires to hit 60 mph in 2nd with 4.88s
    Here's a picture of the Precision turbo:
    click for full size
    Source: https://www.facebook.com/prodigyperf...type=1&theater
    And here's a teaser video Prodigy posted on facebook: https://www.facebook.com/prodigyperf...type=2&theater
    A bit unrelated, but still a new thing from Prodigy, is that they now use TIG welding for their pipes:
    click for full size
    Looks quite a bit nicer than the welds on my pipes. I've been told that the pipes cost quite a bit more to manufacture now because of this. I'm guessing this has something to do with the increased prices for the turbo kits on their website.
