Results 1 to 10 of 73
    This just keeps getting more interesting/exciting!
    We will also be testing a performance torque converter with a higher stall speed.
    No love for us with manual transmission Jeeps? Is there any possibility for improvements, such as:
    * Clutch and flywheel kit (stronger clutch, lighter flywheel). The stock flywheel must be very heavy, because a Dodge Caravan with the same exact engine free-revs like a Formula 1 car compared to my Wrangler. It would be interesting to try to reach a good compromise between lighter flywheel, while still reasonably resisting stalling in slow off-road situations.
    * Mods to the manual trans to make it shift more quickly? I think it takes me almost a full second to shift from 1st to 2nd gear because of the long throw and how long it takes for the 2nd gear synchros to do their job. Maybe I just need to be more forceful to make the shift happen faster?
    7. Install boost controller, return to dyno and achieve World's first Wrangler over 400RWHP ++++
    Do you expect to achieve this reliably on stock engine internals, or is this where the forged pistons become necessary/recommended?
    You seem to have left a very important step out of your schedule: Send UselessPickles a Precision turbo for back-to-back dyno comparison between the Garrett and Precision on the same vehicle, same dyno I also need to make a boost curve chart for the Precision.
    *raises hand*
    Jeeplab's Prodigy turbo has been on the dnyo thrice and will gladly take Pickle's system and test it first!
    Seriously though - I'm highly considering picking one up as MPG doesn't concern me (though mine actually improved with the turbo) and drive-ability is everything. Keep us updated.
