So there was some miscommunication about this new Precision turbo. All the talk of spooling at lower rpms, spooling around 2000-2200 rpm, feeling the turbo kick in around 2200 rpm, etc... I was interpreting that all to be in reference to when boost really ramps up quickly toward max boost during full throttle acceleration. I was wrong.
At full throttle, the boost curve is nearly identical to when/how the Garrett ramps up in boost through the RPMS. In 2nd gear, full throttle starting down near 2000 rpm, I feel the acceleration really ramp up and push me back in my seat right in the 3000-3500 rpm range. Based on my misunderstanding of what Prodigy meant by "feel the turbo kick in", I expected that this shove-you-back-in-your-seat increase in acceleration would happen down around 2500 rpm.
So this is an interesting position to be in. I was initially disappointed and thought something must be wrong with my install causing my turbo to spool up late. I was so focused on it not meeting one specific expectation that I was completely blind to the real benefits. Driving around with my family, my wife and I were in total disagreement. I was saying I didn't really notice a big difference from the Garrett. My wife was saying she could feel a big improvement even from the passenger seat. The big thing she noticed was that it was "much smoother" when we were driving around normally and doing some faster part-throttle acceleration in the mid-rpm range (not flat out full throttle through the entire rpm range). Then I got to a nice straight entrance ramp from a 30 mph road to a 75 mph freeway, dropped to 2nd gear and punched it (probably around 3000 rpm?). My wife let out some PG expletives (kids were in the back seat) then commented on how it took off more quickly than with the old turbo.
Once I got some clarification and stopped focusing on my one incorrect expectation of huge acceleration being available down around 2500 rpm, I started to notice and enjoy the improvements myself. The improvements are actually pretty big, but It's taken me a while to recognize that since my expectations were so different than reality.
Since the full throttle boost curve is not really any different, there's really no data/graphs/charts I can show you to visualize how the Precision turbo is better. It all has to do with how the Precision responds to lower amounts of exhaust flow (part throttle, lower rpms), and how quickly it responds to changes in throttle.
It's really normal daily driving where the improvements are very noticeable. Driving around town and upshifting around/below 3000 rpm, it just feels much better. After upshifting and dropping down to near 2000 rpm in the next gear, the Garrett would feel sluggish/laggy compared to the amount of acceleration you had just before the upshift. The Precision doesn't have that problem. Power delivery just feels more consistent/predictable/linear. This is what my wife was talking about when saying that my driving felt much smoother. With the Garrett, the turbo would just be starting to spool up and increase acceleration just as was about to upshift. The result was often a brief increase in acceleration just before I let off the throttle to upshift, followed by a mismatched (low) amount of acceleration when I got back in the throttle at lower rpms after shifting. It really accentuated the clunkiness of shifting the Jeep's manual transmission during "brisk" part throttle acceleration.
Because the Precision spools up more easily at lower rpms at part throttle, I can often get the daily driving acceleration I want without downshifting, or by downshifting fewer gears than I would with the Garrett. This is a bigger deal for the manual transmission, because it takes effort to downshift. I'm sometimes lazy and don't feel like going through the effort of downshifting just to accelerate a bit faster
Another example is cruising on the freeway at 75 mph in 6th gear. I'm at about 2200 rpm. If I press the throttle a bit, I hear the turbo spool up, and acceleration is a bit stronger than I got with the Garrett in the same situation. It's just enough extra that I can adjust speed with traffic on the freeway more easily without downshifting, maintain speed up gentle inclines more easily without downshifting, etc.
The noises from the Precision are much different. There's a faint turbo whistle sound that I can hear occasionally during normal driving. At full throttle above 3000 rpm, I can definitely hear the turbo whistle. More interesting is that there's a lot more air "whooshing" sounds. I believe this is that anti-surge ports doing their job. It's most noticeable at part throttle. Give it just enough throttle to create some engine load and spin up the turbo, but the throttle is still closed enough that air flow rate is still relatively low. When the turbo is making some boost at low flow rates, that's when pressure backs up into the compressor blades and starts recirculating through the anti-surge ports. This also happens whenever you lift off the throttle a bit after the turbo was making some boost. Under heavier acceleration when lifting off the throttle enough for the BOV to open, the sounds of the anti-surge ports comes just before the BOV sound and they blend together.
Since the turbo spools up more easily at low rpms, and the turbo makes more noise due to its anti-surge ports, I actually get turbo noises much more often during gentler normal driving. I have mixed feelings on this. I like the crisp sound of the BOV, but I don't get to hear that clearly anymore because it's always accompanied by the whoosh of the anti-surge ports.
I still need to figure out why I only get 7.5 psi boost now. I haven't had time to thoroughly check for exhaust leaks yet. I'd also like to compare to MatthewLee - do you happen to know how much boost you are actually getting?
The Precision has a slightly smaller turbine housing with a smaller A/R ratio. It's possible that this turbo creates more exhaust back pressure than the Garrett. Since we're simply using wastegate spring pressure to control boost, it's actually a balancing act between the spring, boost pressure, and exhaust pressure that determines when the wastegate actually opens. It's possible that the Precision just makes less boost than the Garret with the same wastegate spring due to higher exhaust back-pressure (increased exhaust back-pressure would also be part of why it spools up more easily at low rpms). I'll try to get some info from Prodigy about this.
