The 3.8 turbo kit that makes power like a supercharged 3.6 is a higher pressure kit (12psi). My prediction is that the 3.6 turbo kit will be a lower pressure kit like the standard 3.8 turbo kit (probably around 8psi), and that the standard 3.6 turbo kit will produce numbers similar to the 3.8 12psi turbo kit. The stock 3.6 starts off with better high RPM torque than the 3.8, and has a higher redline, so I bet the 3.6 turbo will make more power than the 3.8 12psi turbo. I'd guess around 400hp.
Maybe they'll introduce a 12psi kit for the 3.6 in the future to get that 500hp
