JL Decals.... HMMMMMM i heard something about them once...
as far as the stages, It seems simple at first but then, it gets more complex. There are sooo many options for so many wheelers.
I say -
Stage 1, - 2.5" Flex, keep your stock flares run 35s, - Leaves option to go flat flares and go to 37s in a later stage.
As far as a power mod, I say you walk a fine line. BB may be perfect, as a manual trans, Sweet Pea may be perfect nooooow, after months of waiting. The turbos are still having problems.
If you are going to go power mod make sure whoever you use is going to stand by and be accountable.
- You may not post replies
- You may not edit your posts
