Results 1 to 10 of 33
    I will say the the installation manual is really quite good. However, you'll find that the bolts on the back are difficult... My hands were sore for days after that. Take your time with those. Smooth and easy is fast.... Don't forget to put the long bolts through the top before setting the sc/top manifold on the lower manifold. Also, lay out the hose spring clamps and make sure you use the correct clamps on the right hoses. I initially didn't and had a couple leaks that I ended up fixing with normal screw type clamps. I posted several pics on another thread that may be helpful to visualize the process. Good luck... If you want to pm me, I'll give you my direct email address if you want to reach out with questions.
    Quote Originally Posted by rgeorge33 View Post
    thanks! will do if i hit any snags when i install it next week
