Cherry Bomb is a Sahara. I knew going in I'd be changing axles at some point and I wanted ARB air lockers and manual sway bar disconnects. Front axle is a D30 which has same tube and C size as the D44 but with much smaller ring and pinion. Hemi or not the D30/44 will bend at some point and be replaced by ProRock D44/60 or an equivalent.
