I don't have the loop delete but I do have the wideband. I wouldn't worry about drilling your stock pipe. Drill, weld...good to go. Easier than cutting into the stocker and clamping up and you save a couple bucks even if you have a exhaust shop do it. They give you a plug for the bung if you pull out the wideband sensor. Let us know how the wideband turns out. Interested to see how it goes. I haven't had time yet to put mine on. Got the gauge installed and looking good but not wired up yet. And to may be answer your question : yes Ripp says you'll need a different tune when you delete the pipe. Foxsat is possibly dealing with that problem right now. It throws a code. After you install the pipe, call Ripp and get a different tune or possibly get tuned from a local tuner after you install the wideband.
