Thanks for the inputs! I'll have to check the price comparison with the KO2s and get back to you. Be glad you aren't over here now. Now that I'm a contractor advising the Afghan Air Force (used to be an Army Longbow pilot) only having the pea shooter on my hip is not reassuring! I also need to double check on the weight of each as well. Thanks again and if you haven't seen the STT Pros check them out. I need to do research the KO2s. LongbowDriver
