I don't have experience with the STT Pro. I do have experience with KO2 and a different Cooper tire (Discoverer AT3). I can't do a fair comparison, because the Cooper AT3 that I had is such a different tire from the STT Pro. All I can say is that Cooper makes great tires. The KO2s are decent tires, but it took quite a bit of weight to balance them and I still don't think they're perfect. They also don't seem to do as well on standing water during hard rains as my Cooper AT3s did. I don't know if that's because of the tire compounds, tread design, or what. Sooooo... I really don't have much worth while to say except overall I think Cooper makes better tires than BFG. Just one guy's opinion.
Thanks for the inputs! I'll have to check the price comparison with the KO2s and get back to you. Be glad you aren't over here now. Now that I'm a contractor advising the Afghan Air Force (used to be an Army Longbow pilot) only having the pea shooter on my hip is not reassuring! I also need to double check on the weight of each as well. Thanks again and if you haven't seen the STT Pros check them out. I need to do research the KO2s. LongbowDriver
