Voters
  • EDELBROCK E-FORCE
    1 10.00%
  • RIPP
    2 20.00%
  • SPRINTEX
    4 40.00%
  • MAGNUSSON
    3 30.00%
Results 1 to 10 of 50
    but then there is the 2" lift, boost controller, it seems to keep going.
    If you don't take the Jeep off-road, you could probably get by with a simple leveling kit (0.75"-1.0" spacers in the front only). That's what Prodigy uses (or used at one point) on their test vehicle and never had any clearance issues with street driving. The 2" will absolutely guarantee that there will never be any clearance issue, even at full compression after accidentally going over the top of a sand dune a bit too fast and catching some air (yeah; I definitely need the 2" lift).
    A hybrid might work: 0.75"-1.0" spring spacers in the front + 2" bump stop extensions in the front "just in case" to make sure the front driveshaft could never touch the exhaust.
    Boost controller is completely optional. The kit has great power without it. Adding a boost controller is just an inexpensive/easy way to add even more power.
    My next mod might be brakes
    I see this mentioned a lot that you have to upgrade brakes to match engine power upgrades. This is true... for race cars. Race cars need braking capability proportional to their acceleration capability. On a race track, the quicker you can accelerate, the faster you go on the sections of track between the corners, and the harder you have to brake for the corner because you'll be braking from a higher initial speed.
    On the street, no matter how fast you can accelerate, you're always going to stop accelerating somewhere around the speed limit. No matter how much power you have, when it comes time to brake, you'll be braking from the same speed. The only things that may require more braking power on the street are much bigger tires and/or more weight (lots of heavy bumpers/armor, towing, etc).
    Just got off the phone with Dan Marra of Prodigy. He said I should be able to get by with just taller bump stops if I am not doing serious off-road stuff; apparently that is how the Prodigy red Jeep is setup.
    Dan offered me a good deal, so I guess it ain't over. I am seriously close to "pulling the trigger" on the Prodigy Stage II with Precision Turbo, Journal Bearings, Heat Blanket, and Mishimoto 180 F T-Stat
    If it works for them, and your type of driving is similar to theirs, then I would consider replicating their setup exactly (find out exactly which brand/model product they used). But I would still mentally prepare myself for the possibility that you might run into slight issues if you happen to hit a particularly big bump, pothole, railroad crossing, etc., which will force a decision between altering your driving style to avoid those situations, or consider other options of small lifts or leveling kits to decrease the chance of clearance issues.
    My prediction is that 2" bump stop extensions combined with a 3/4" or 1" spring spacer in the front would be the best compromise. The 2" bump stop extension will guarantee that it will be impossible for the driveshaft and exhaust to collide. The small amount of lift in the front will minimise how much stock suspension travel you "give up", and allow some decent amount of travel before the jounce bumpers contact the bump stops. When the jounce bumpers hit, it will have an effect like suddenly having a stiffer spring (not sure how much stiffer though), which could make for an uncomfortable stiff ride if the jounce bumpers are routinely hitting during normal daily driving on typical bumps on the road. A 1" lift in the front would have a bare minimum impact on appearance and handling. You may even think the Jeep looks better, since the vehicle will be more level instead of leaning forward.
    Any particular reason for the 180*F T-Stat? I didn't even know that was an option. I still have the stock t-stat and have not noticed any cooling system issues.
    [QUOTE=Any particular reason for the 180*F T-Stat? I didn't even know that was an option. I still have the stock t-stat and have not noticed any cooling system issues.[/QUOTE]
    The 180 degree F Thermostat is supposed to be a good way to keep engine temperature cooler according to Dan. I am guessing that they have had good results with that setup?
    Pull the Trigger on Prodigy Stage 2! i was the 3rd after Jeff and Jesse to get the turbo for the 3.6 for my 2012 JKU. Prodigys' come a long way from their first tunes, and i can tell you first hand how much their tunes and calibrations have improved over the years. i dont think you can go wrong with the Ripp Charger either they have a great product as well. whichever you go you wont be disappointed, both will deliver very noticeable power. I went with Prodigy personally because i like nature of exhaust driven turbos and the power they can deliver. I dont have my jeep anymore though Sold it and bought a house. However ive got a 2015 JKU-R and yes i will be putting prodigys turbo on it Dans ready and waiting for my order
