Results 1 to 10 of 69
    Instructions make it a breeze...
    3.5 hours in -
    New manifold hosed up!
Name:	JeepLab Magnuson Hosed Up.jpg
    Instructions are some of the best I've seen. Big color pictures.
Name:	JeepLab Magnuson Instructions.jpg
    Manifold complete with fuel rails and getting married to supercharger
Name:	JeepLab Magnuson Marrage.jpg
    Manifold and supercharger married.
Name:	JeepLab Magnsuon Mirrage.jpg
    Now attention is back in the engine bay. Modding hoses. The left pcv hose gets cut and reinstalled, the the main engine harness is unplugged and re-routed , then the heater tube is removed.
    *note - when removing the heater tube loosen the radiator cap to relieve pressure. So you don't spray the coolant that's under pressure
Name:	JeepLab Magnuson 11.jpg
Name:	JeepLab Magnuson 12.jpg
Name:	JeepLab Magnuson 13.jpg
    Heater hose modded with 90 degree turn.
Name:	Jeeplab magnuson heater hose.jpg
    The Dremel makes another appearance, trimming the center wire harness stud
Name:	JeepLab Magnsuon Cut Stud.jpg
