Here is the dyno chart with the original dyno on the same page.
Here's what you have to understand. In 4th gear, when we started, the truck had a speed limiter that we hit around 5500 rpm. Thats why the band is shorter.
In 3rd gear we got around 220 hp. keeping away from the speed limiter.
4th gear is more the 1 to 1 with the stock tires, and without the limiter you can see the results. I only mention it, because I think the pentastar makes about 225 "uncorrected" which makes sense and agrees with black betty's stock dyno last year.
So this is the chart of both 4th gear pulls, but the lower one is short because of the speed limiter in the JK that was removed with the magnuson tune. (thus we don't hit it after)
Even tho we didn't get the same numbers magnuson got, that torque curve is pretty sexy.
Stock vs. Supercharged Dyno Chart
Name:	Magnuson Dyno Stock Dyno Laid over.jpg
