Recently completed the installation of the pre-owned Magnuson Supercharger that I acquired from gbaumann. I am embarrassed to post pictures now because I have a jerry-rigged PCV breather/catch-can setup made of scraps. I was not planning on bending stainless steel as the gbaumann, but now I am actually considering that, maybe with copper. I purchased some type M 1/2" cooper and figured I would plumb it with push-fittings and use rubber hoses at the catch can.
Regarding the Magnuson with my Manual Transmission, it does not knock your socks off. It drives way better than before and feels more or less "as it should," probably similar to a 5.3 Vortec V8; does not push you back in your seat, but has a nice and wide power range. I am very pleased with it thus far.
Install was a bear mainly because I had to piece some things together and wait on parts. Many thanks to gbaumann, Brian from superchargers online.com, Garrett and Simon from Magnuson, as well as everyone on JeepLab.
I probably will not dyno the Jeep, but I will post some after pictures and I may try and do a 0-60 run.
