Didn't you have a dyno run of stock in 3rd gear that allowed you to test the full RPM range?
I have the 3rd gear pull for stock, but 4th gear is the better 1 to 1 ratio. I don't have a 3rd gear dyno for the supercharged trucks.
If you want to see them on the same chart, its going to be in 4th gear. The 3rd gear number I think was about 185, I don't have a supercharged 3rd gear pull to put beside it.
