Results 1 to 10 of 244
    Im hoping to have the high altitude pulley on the RIPP this weekend
    How much extra boost do you expect the high elevation (ugh, high _altitude_ even though altitude is for airplanes, elevation is for "earth") pulley to provide at your elevation? Does RIPP really support using this pulley at sea-level type elevations?
    weather or not RIPP supports using it at sea level, im not sure.
    However, im at sea level. and Im expecting it to make around 12lbs of boost. (Betty is supposed to have about 8lbs boost now)
