Results 1 to 10 of 244
    Quote Originally Posted by Bullfighter View Post
    if it does detonate the motor than an excuse to drop a 5.7 would almost be legit
    The 5.7 hemi isn't really worth the money for the conversion from the 3.6 Pentastar, especially if you're coming from a supercharged Pentastart. 5.7 Hemi only makes about 230 hp at the wheels in a Wrangler. Only about 40 hp more than the stock Pentastar, and substantially less than a supercharged Pentastar. That would be a $20k downgrade from a supercharged Pentastar. If you're going to do a V8 conversion, go for a 6.2 LS or 6.4 Hemi.
    Anyway, the double catch can I think would be excessive and more hoses.
    I agree that a single catch can (on the make-up air hose! not the PCV hose!) is perfectly adequate, to reduce oil vapors going into the intake during high engine load/boost conditions.
    Junior Member Bullfighter's Avatar
    Aug 2014
    Northern WV
    Blog Entries
    1
    N
    The 5.7 hemi isn't really worth the money for the conversion from the 3.6 Pentastar, especially if you're coming from a supercharged Pentastart. 5.7 Hemi only makes about 230 hp at the wheels in a Wrangler. Only about 40 hp more than the stock Pentastar, and substantially less than a supercharged Pentastar. That would be a $20k downgrade from a supercharged Pentastar. If you're going to do a V8 conversion, go for a 6.2 LS or 6.4 N
    Haha no I'm in no hurry to put a smal block in. Financially or even want to tackle it. Let's just say if the 3lbs of boost makes it blow than the 2 door jeep is gone and a 4 door will show up in the garage.....which isn't cheaper but damn at this point stock and untouched would be less stressful.
