Results 1 to 10 of 244
    Thats good info on the guy doing the tuning. It sounds like a experienced tuner is probably the most important part of the whole process regardless of system one chooses. Thank you for your input
    Quote Originally Posted by ferrarifast View Post
    That is a step beyond. The tune out of the box should be good, Only if you have problems, would I pay someone to customize the tune.
    The tunes take months to build, and the tuners at Ripp, Mag, Prodigy, are people who do nothing but tune.
    I'd trust them first, and if you find parts you don't like, id tell the manufacturer first, see if they can correct the tune for you. If that fails, then pay a tuner.
    I would not jump to screwing with an established tune until i knew i had a problem with it that the person who made it will not solve. Also, your paying by the hour, so to be able to state specific problems that need attention rather than something general will keep the cost down.
    "I have a dead spot at 2500 rpm in 3rd gear" "the throttle surges at cruising speed" Stuff like that. Pinpoint the problems first, it will save time and money.
    finally, and most important, make sure you have a competent shop. Needs to be a race shop or tuner where the person tuning knows what they are looking at. You don't want some fool with a dyno screwing with your truck. Check references. google the shop. look at it like selecting a doctor to work on your child.
