LOL, not a wrench?
have you got a sound byte of the hi alt? Ill post standard alt next to it.
No sound bytes, don't have'm. Wrench? I didn't think I would have to go from beginning to end here. Nuts and bolts is all but if you really need the details then an impact wrench is a must. Spin the nut off. Put the puller on and crank it to until the pulley comes off. Carefully tap the pulley down with a piece of wood and use a thread locker when u re-torque the nut. Re-install and possibly reprogram. It's that simple. Now if you want to get really crazy install a catch can too. You won't believe the amount of oil you get going into your intake. The catch can install will probably take longer to do. Good luck
