As far as a catch can I have one, if you install one be sure to plumb it into both pcv lines from the left bank and right bank on the engine
I hope you mean to use 2 separate catch cans: one for each hose. Definitely don't want to run both hoses through one shared catch can, or else you'll have a vacuum (and boost) leak and won't be drawing fresh air through the crankcase.
