Results 1 to 10 of 244
Threaded View
  1. #3
    Install
    We didn't install our RIPP unit, but we can pretty much see how it was done. We did the MAG unit ourselves in under 9 hours overall with an hour break in the middle.
    The RIPP install is the more invasive of the two. People say you can unbolt and go back to stock if you want. With the RIPP unit, its not quite that easy. there is some sections of the engine bay that need trimming to fit the pipes thru to the intercooler. You are not fixing that after the fact. So there will always be clues to anyone looking that the engine bay was modded at some point. The trimming isnt severe, but its there.
    You will also change the coolant bottle with the RIPP unit. Something else to hold on to if you thought you might uninstall in the future.
    Here's the finished product
Name:	RIPP JeepLab.jpg
    The magnuson install is borderline easy, and less invasive. You will cut some hoses, but nothing that cannot be undone later. It does have a flaw however. When you install the coolant pump, you'll see its low in the engine bay. About the same level as the bumper. This pump is water "resistant" but not "waterproof". So its a consideration you have to be aware of off road. We think they will relocate it in the future, or change to a waterproof pump, but as of today, its not.
    Installation Winner: Magnuson
